Hello!
I’ve been a Cinema 4D user for years (since version 6!) but just recently tried Corona, and I must say I’m hugely impressed by the speed and quality of this renderer. Kudos to the devs! ![]()
The C4D integration seems to be very good, however the thing I’m missing the most currently is deformation motion blur.
Since I’m doing characters and animation a lot, this is a fairly essential feature.
In a desperate attempt to make it somehow work, I tried using sub-frame motion blur, and to my surprise it worked (I’m talking about the C4D in-built, not-Corona-specific effect, which you apply in the render settings via Effect → Sub-Frame Motion Blur).
The joy was quickly over when I found out that if I use this effect, all the textures in my scene are ignored. The frame gets rendered with all lights and geometry, the deformation motion blur looks wonderfully, but there’s not a single texture.
Does anyone know a trick or workaround to make Corona use textures AND sub-frame motion blur?
Thanks a lot in advance
Günter
