it will be a bit handy if sub menu under Corona / New material
clay/default
glossy
glass
Volume
metal
plastic
xxxx
xxxx
will be fast way to place materials on objects and later set a required.
Thanks.
clay/default
glossy
glass
Volume
metal
plastic
xxxx
xxxx
Thanks.
What you’re looking for seems to be a material library that pops up when you select the shader creation.
Just use the library of the materials, it’s called presets and located a few pixels to the left.
