What should I do ? Manually set path ?
Runtime error: $directory not recognized: $(scene_path)
Hey,
You need to set an absolute path in the Output settings before submitting the scene.
You can find more information about it here - Chaos Docs
Also, are you using Phoenix’s submitter or Deadline’s?
Well, both of 'em not working. I think of creating sysvar with current correct scene output per scene. When submiting lots of scenes - manual output is unrealistic.
Sure, vars are supported, so go ahead.
I wonder, why this check is needed at all? When submitting scene, without copy with job - it is plain max starting without gui. So, it can resolve phx default variable, right? I can’t understand the purpose of this check at export time…
This check is not in Phoenix …
Yeah, I see. Wonder how to remove it ![]()
Try using $(scene_dir) instead.
Still need preprocessing script that chanes output. I’ve asked dl guys, so maybe they can mod thier scripts, so users wont have to do anything.
