Substance Painter Batch Loader
  • Substance Painter Batch Loader⁣a real time-saver****My latest 3dsMax script to load multiple pbr texture sets that generated using substance default export presets for chaosgroup vray and Corona render engines then create material based on the engine you choose using those texture sets with correct gamma applied.⁣
    there is also an option to add color correction node for greater control ⁣
    you can create a new view for the slate material editor and put created material into it to help you organize in a better way⁣
    if your texture sets have an emissive channel for emitting light you have also an option to create Corona or VRay light material instead of the default material⁣
    if you do not want default 3dsMax bitmap loader you can use VRayHdri loader for VRay and CoronaBitmap for Corona renderer (actually it is the script default behavior)⁣
    you can also control blur for all three bitmap loader, separately for diffuse and all other channels[/li]
please, see the preview video to see what it does.
Download Link:
https://www.artstation.com/acinonyxlord/store/VrlA/substance-painter-batch-loader-for-3dsmax
Mohammadreza,
I recently purchased your Substance Painter Batch Loader tool, and I am already having problems with it. I am unable to load the texture sets:
ERROR: “your texture selection set is not complete”.
Please advise(?)
please message me in Instagram (@mohseni.mr) or Whatsapp (+989177039147)
and send me a screenshot of that error as well. thank you
