Suggest: I hope that enscape can support "model appearance diagram", or "circle object diagram".
Suggest:
I hope that enscape can support “model appearance diagram”, or “circle object diagram”.
Purpose: Used to show customers the appearance of the model, such as: the appearance of the building, the appearance of the product…
These pictures are a set of pictures formed by rotating the camera around the center point (Z axis) of the model at a fixed height, and taking a picture for each rotation angle. .
The basic operation points to realize this function:
  1. Set the center (Z axis) of the model to be displayed
  2. You can set the height of the camera
  3. You can set the rotation angle of the camera to shoot one frame (use to customize the number of a set of photos)
  4. This group of photos can be saved in a folder in batches, which is convenient for users to use
  5. I only think of these points for the time being, and other users are welcome to discuss together
This function is very useful. It can achieve a good display effect for designing buildings, villas, houses, product design, cars, and any models. I hope enscape officials can support this feature as soon as possible. Thank you.
The enscape forum cannot upload pictures directly, it can only be displayed through links. You can see what I mean by clicking on the link.
This topic doesn’t seem to be popular
Why is there no one to discuss such a good proposal?
LOL why you so impatient?
  • turntables have been suggested/requested before.
But yes, would be a nice to have.
What seems important to you might not be that important to others, who would’ve thought?
Do you mean somethinkg like this I knocked up:
Inside out pano / web rotate test
+1
You can also do this by rotating the camera without using the turntable.
Quite, and I should’ve said “turntable effect” as we’re never going to spin our model geometry!
Re my link above:
I setup 8 scenes per 360, ie every 45deg I then created a 2 second animation with scenes 1,2,3,4,5,6,7,8 and 1. I rendered as jpgs and got 60 stills.
I created similar orbits every 10deg higher all with the same look at point and got 60 images for each one.
One thing I had to do was edit the xml files to ensure it was 2.0000 seconds and not 2.xxxx as even the slightest difference will result in 59 or 61 images.
In fact, my needs are a bit simpler, because I only need to rotate the jpg picture in a circle, and every frame of the picture taken by the camera at the same height. You do not need to generate xml files. I can use Object2VR to make xml web files.
https://ggnome.com/object2vr/
The xml’s are the saved animation paths in Enscape so infact you do need them.
It has been 2 years. I hope the suggestions can be adopted or valued. Thank you
I think it fair at this point to say you have a point
