Sun and Detail Enhancement
It is nice that we have a sun now but I seem to be using it poorly. I will admit that I am used to the Flamingo sun where you turn it on and it acts like a sun without a lot of choices. When I do sunlight here my object is completely blown out by the default. It asks for ‘position’ what should that be set at? (i’ve tried near and far (but not like outer space far) Are the defaults for the light OK, or not? Do units matter on this? (i’m in cm)
Also, in another post there was talk of ‘Detail Enhancement’. What is that, where is that and how is it controlled. Sounds pretty interesting.
There’s a bunch of stuff under Material Editor>Maps that I have to figure out as well. Thats good.
Re: Sun and Detail Enhancement
Paul, if you like download my latest beta 2 starterkit:
You will find a sun in action. To avoid the bright light you have two choices:
* use physical camera (DOF dosn’t work at the moment)
* use standard camera and set the multiplier at the color mapping options at a very low avlue like 0.02 (look at my sample file)
The sun is a directional light und only the direction angle count, you can place it where you want. It should be unit independent.
Detail enhancement: best you look at the help of www.spot3d.com
Thanks. Detail enhancement is good stuff.
I’ll play with the sun later.
Paul
The position only comes into play when using the Sun as a photon emitter. Just a minor ammendment to Micha’s post - but he is correct, the position doesn’t affect the overall intensity. If your scene is too blown out then you should really modify the physical camera - not make the sun less bright.
This is only half true. The position of the sun does affect its intensity, but not significantly enough to counteract an incredibly burned image. The affect/intesity of sun in the morning/evening will be visibly different then at midday, and if you set the time of day to 2 in the morning your image will be dark even without a groundplane. The physical camera is really the only way to go when working with the sun and sky model. Once you get used to working with it the whole system works together pretty smoothly. Keep in mind that it is important to use gamma correction/linear workflow with the sun and sky other wise your background (the sky) will appear too dark.
I think he was talking about the sun position in the drawing (the representation of the sun)
I use gamma correction and LWF and still can get a background map reflection,as soon as I set a background map all I get is black.If I remove the map,I get a reflection but of the generic sky.The only way for me to have a reflection in the glass is to set a reflection in the material.
Renee
Placement of the sun dosn’t matter. You can place the Rhino sun light within a scene room for example, it dosn’t matter, it come from infinite distance. Only the direction of the sun light count. Flat angle - evening/morning and … .
I like this kind of sun control. So it’s very easy to set the sun in a specific direction. :slight_smile:
I’m curious for a working sun intensity control, I like a less ratio between shadow and sun.
ok, I misunderstood a little. In that case the placement doesn’t matter only the vector.
I’d try a lower sun intensity and higher GI intensity…turbidity might also play a bit of a role.
Sun intensity control dosn’t work, it control the intensity of sun and(!) sky.
Renee the problem that you have run into is because of two issues. The first has to do with the physical sun/sky/cam relationships and how they relate to and influence the appearance of the scene and ultimately the materials themselves. There is a very detailed tutorial/explanation on the chaosgroup forum here. Just make sure you are registered and logged in. We’re in the process of developing a counterpart for Rhino, so it might be something you will want to look into. The second issue, which is much more pressing imho, is that using the Correct RGB function actually causes an incorrect influence of you colors. Unfortunately this extends to reflections because colors are chosen for reflection values. I noticed this a while ago, and here’s the thread that discusses that
Yea its not really working for me either. Its not that changing the ratio between sun and sky doesn’t do anything (its just changing the colors from slightly yellow like the sun, to a bit bluish like the sky). Its just that it doesn’t really soften any of the shadows. I agree that there should be some way to soften the shadows. Joe said there was a way to soften them, but I haven’t found it yet.
Soft shadows of the sun works fine here - set size multiplier at a value between 1 … 50 … or more.
thanks Damien,
The materials are fine,and the lighting also,what is black is the background.As for the soft shadows it works like Micha said,no problem here either.
Renee
Thats good to know. I never really messed with the sun size, so I would have never have found it. Thanks.
I know you think they are fine (and the are for the most part), but you’ve got to watch the tutorial. It will explain what is happening with the whole sun/sky/camera system and will work much better for you. I could explain it, but it would be much better to watch the tutorial, as Lele explains it much more extensively then I could in a thread. Again here is the link http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?t=17824
Ah yes Damien I have downloaded the files a while back and watch them.But I can’t figure out how to set the rgb at .255
may be there is something I don’t understand,it is not easy trying to translate the info for max in something that could be use with VfR.
Renee
It’s no secret, I would not use the 0.255 method, because the side effects. :wink:
@Renee
In order to adjust the colors it is advised to use the Acolor type in the texture editor. Simply set you color in the Acolor Map as you would normally, then decrease the multiplier (underneath Type, not the Alpha value) and you should be able to get the colors to work. With textures simply decrease the multiplier and everything should be good to go. Sorry to lead you down the road with no helpers, but I wanted to make sure that you watched the tutorial first. Also, are you using the vray sky for your environment/bkgd or an HDRI?
@Micha
I know it isn’t a secret that you wouldn’t use the method, but I would encourage you to maybe take a new look at the tutorial now that we have the Physical Sun/sky/cam. Lets let users determine whether they want to use it for themselves. If you want to discuss the “side affects” then we can do that via email or something :wink:
Good idea. :wink:
PS: Next week two current projects should be finished, than I could do more experiments again.
Damian,
I use the vray sky.
It is the reflective background that I can get to reflect.The sky I don’t have any problem.
I did test the RGB at .255,and frankly I can’t see any differences in the 2 renderings.
Renee
I’ll have to look back at some of my notes for using that workflow with vfr…You should still get reflections to be fine. Is the background at least looking how it should?
I will try to explain a little bit better.
1)Doing a rendering,with vray sun and sky,looks perfect the sky reflect in the glass,no problem.Except all I have in the glass is a gradient with no clouds or buildings etc.
And I want an environment that will reflect,so I enable reflection background and set up a map correctly,and hit the render button,what I get is perfect lighting,but the background is pitch black and the glass of course because they are reflecting the black background.
I tried to disable the sky but keep the sun and the reflective background,same problem.
I must do something wrong,but I can’t figure out what.Thanks for your time.
It is a long weekend here so I will try and find a solution.
Renee
