Hi all,
I have a question regarding true day/night cycles in Corona. I used this method to link the Corona sun to the physical sky renderer to get accurate times of day:
However when the sun sinks to the horizon, instead of disappearing and darkness falling, the sun floats along the horizon at an angle of what I can only assume is 0 degrees before rising again on the opposite side of the sky.
When I removed the link and tried it with just the sun, same issue. I know it should be possible since there’s a Corona animation showing a rising sun in this thread:
https://forum.corona-renderer.com/ What is corona sun object ´textured´ ?
I’ve attached my scene showing the lowest I could get the sun to render, which prevents any sort of true day-into-night animation. Any ideas?
SunTest_082918.c4d (163 KB)
