I found that RMB+Shift is changing the “daytime” by moving the sun up/down only. It’s ok, but I miss a way to move it horizontal. Could be nice to add an option like Ctrl+RMB. It’s needed to adjust the sun for an animation so that the sun light goes from one side of the room to the other. OK, for still images I can use the Rhino sun control, but this control isn’t taken in account for animations.
The normal way the Enscape sun works is by specifying a location and date/time. This is supported by Revit, SketchUp and Rhino - Enscape simply reads these values and allows to change the time via Shift + RMB.
But there is another option for Revit and Rhino, in which you specify the azumith & altitude of the sun. (Revit: “Lighting” sun settings, Rhino: Sun “Manual control” on) In this case Enscape can’t work with location & time, and therefore simply adjusts the altitude when changing the time.
I suppose you have manual control on and I advise you to use location & date/time for a more realistic sun animation.
