Sun direction
Hello Friendzzzz,
Does anyone know how we can change the altitude of the sun, or its direction,
I need for for changing the shadow ,
Regards
NJ
Hi
You control the position of the sun using the Sketchup shadow windows or shadow toolbar. To open the shadow toolbar, go to View on the main menu, then click on Toolbars and select “Shadows”. To open the Shadows option windows, click on Windows on the main menu, then select Shadows. Now you are going to be able to change the month, days and hours. You can also setup your sun position using the Geo-Location under the Model info.
Best
ahaaaaaaaaa,
I hadn’t thought about it!!!
I thought the shadow in SU inteface is not related to vray rendering , ,
I will try :slight_smile:
chx
NJ
