Sun location changes when render peset view
When I render a preset view, the position of the sun changes. Why does that happen?
@M_Duyndam
In case you are using Enscape 4.19 or earlier, we found an issue with the sun position changing under some special circumstances. I´d recommend to update to the latest version since a bug potentially triggering similar behavior has been eliminated in that version.
Should you already use the latest version 4.20, I´d like you to send us a feedback report with log since our devs would have to look into what is happening.
Thanks!
