ArchiCAD 22 with Enscape 2.6.0-preview.5+9425
I encountered a bug with the sun path. No matter which month or day or geographical position I use in ArchiCAD settings, the sun moves in Enscape as if I where at the equator. It is completely above the model, see pictures. If you look at the column on the picture, the shadow has no sideways movement and I can’t get any sunlight to the room as well. In ArchiCAD the sun behaves as expected.
Please fix this issue.
