the sun stopped working this is how the picture looks on the street, even in old projects where everything was good the sun stopped working
what could be the problem ? maybe the video card driver has been updated… ?
перестало работать солнце вот так выглядит картинка на улице, даже в старых проектах где было все хорошо солнце перестало работать
в чем может быть проблема ? может драйвер видео карты обновился… ?
the settings are the most standard I have not changed them…
the HDR sky works but the sun doesn’t.. I tried opening old projects where everything was fine.. the sun doesn’t work there either.. even if I open an empty new project and put the sun all black
Ok, it sometimes happens that Corona fails to license correctly and then some issues could be appearing. Could you please try the “Solution A” as described here?
