Hi all,
Is it me or was I able to create a sun size of, for instance a 100, and is the size now limited to a maximum of 64?
Thanks!
Hi all,
Thanks!
IIRC I’ve decreased the size because of some problems. You should really not use such big sun. Use environment map instead.
pff, that is a relief. noting wrong with my memory.
I used the larger sun sizes to add a bit more contrast to my environment shadows. It worked perfect for me.
Never used more than size 100 btw so 64 seems big enough.
Thanks for the answer keymaster.
