I thought different color modes in Sun settings are there of changing scene AND sky/clouds system like Corona introduce in version 10. But I found I cant change sky and clouds to a overcast night sky.or something like that. Will you add this feature?
Hi, thanks for posting. Could you explain a bit further your question. The VRaySky and clouds are affected by the Sun’s height and Sky model (CIE Clear, CIE Overcast and so on). Are you referring to something else?
V-Ray 6.1 adds a “density multiplier” parameter for the sky clouds that can be used to achieve an overcast look.
Regarding the sun color affecting the clouds, some Corona users reported this as unwanted behavior as they only wanted to control the illumination produced by the sun but without changing the appearance of the clouds. Maybe an option for this is needed…
