With rectangular light, I could make natural and soft shadow, but if I add sunlight system and make it as sunlight source in GI setting, it creates too harsh shadow.
Need help.
Thanks a lot!
Need help.
Thanks a lot!
Re: Sunlight system creats too harsh shadow?
Hi Inthemood
Go to the sun parameter and increase the size of the sun to produce soft shadow.
Best
Thank you, Fpedrogo.
I tried Indirect Illumination-Primary Engine, multiplier and Environment-GI-Texture Editor-Common-Type, Sky. Intensity multiplier and Size multiplier.
None of them gave me soft shadow. I can’t figure out what you meant by " the sun parameter."
Could you let me know in what setting I can modulate the size of the sun?
He refers to the Size parameter of the Sky map in the GI item under the Environment section.
Thanks.
However, it works only when I don’t use sunlight system as sunlight source.
The override parameter of the sun in the environment doesn’t work. That is a known issue. You have to increase the size of the sun through rhino object properties. So, disable the override sun on the environment GI(Skylihgt) and on Background. Select the light and type “Properties” on command line, then select light on the properties window and change the size parameter there.
Best
yap, like Fernando says you have to insert a real sun, and dont’t override it, control it from the rhino properties by increasing the value of the size mult in the light parameter. Remember, bigger numbers make shadows softer, but too much it tends to dissappear, so, size will depend on you scene scale.
but how to select the sun? does any light in the scene become the sun? i don’t understand this. ??? and i have the same problem ![]()
The sun is a direct light, but to control it you use the Properties in the rhino UI. To Insert a sun there is an icon in the V-Ray toolbar (a sun like icon, well more like a spot light).
Also this should be inportant to Download.
