Since last month the sunlight in my scenes isn’t working… the render has the correct illumination, but in the areas where the sun supossed to appear there’s nothing but a little spot of sunlight… I’ve tried a lot of different v-ray settings, but still not working, and it’s annoying, badly! I’ll really appreciate any help…
Do you use the physical camera? You need to use this camera I think with the sunlight system. I have had the same and using the physical camera helped.
Also you have a lot more settings like with a real camera that will help to make a realistic render.
