Sunset
My first test with photoscan. Rendering in Corona. 3d max 2014.
Camera: Iphone 6
Model: PUMA by Rihanna Creeper.
https://www.behance.net/gallery/38157897/Sunset
Ou man I rly hated those shoes when I was kid :smiley:
Nice render. What about mesh? How heavy model is?
Hello
I find your shoes and your genial 3d scan, you used that software? have you added a camera on your iphone ?
thank you very much
Thanks) I think you hate another similar model shoes, because it’s new sneakers by Rihanna :wink:
Polys: 602 818
Verts: 301 617
Hi! Thanks! To create this model i used Autodesk 3ds Max/ VisualSFM/ Corona render
I do not understand your second question … Do you want to see a photo that I used in the process of creation?
Hi, I think he wanted to know if you used a separate camera extension(hardware) for the iPhone…
Probably not, you will be surprised how much photoscan can pull out from even the lowest quality photos.
Also, really awesome work!
Is the sole of the shoe translucent / SSS because it is the diffuse texture of the reallife capture, or did you add translucency / SSS with the corona material?
looks real.. great work man.
No, i used only the original iphone 6 camera.
Thanks) All material taken from a scanned model without SSS only reflect, refl. gloss and bump.
Thanks man!)
