sunset
hi, i haven`t much experience with dusk-night images. as i want to improve my skills in this issue i did this image.
i would like to better it, so c+c very welcome
That is a good start. A bit too realistic, if you ask me. People tend to like saturated, colorful sunsets and dusks. Bright yellow incandescent lights, vibrant blueish violet sky, and orange casts above the setting sun. The setup you have here is a typical clear day with a bit too realistic white balance.
The whole image could be a bit brighter, and a tad more contrast would enhance the dusk atmosphere.
A.
thanks for your reply, will make an upgrade of the image.
i made another version of this project. i realice that i have a problem when it comes to make a fitting sky for sunset images. in the image below the sunset is in front of the building therefore the sky on the horizont should become darker-and not broghter as it is in mine. problem-i don`t have this kind of sky…
you could always mix your sky image with a vraysky
