Hi all,
this is not a finished project.
I started it with Octane for Max then when I knew Corona I said: why not?
The scene is huge, 800Mb.
I don’t know if Corona supports proxies but definitively it needs this feature enabled.
I’m very surprised about Corona. Being it in an alpha stage is already a productive tool to render masterplans.
I found an issue with Forest Pack Pro using my cutout people: because to create the opacity map I used the CoronaMapOutput and set it to grey, loading the scene Forest Pack doesn’t refresh this node and I have to manually check it and refresh it for each multi material slot.
Every image is rendered for 1h, default setting (alpha 5)
The tree forests produced sometime some hot pixels. I deleted them using Dust and Scratches in PS.
regards
