Dear GPU team
I would like to suggest to support animated 4d people from AXYZ anima.
Plus it would extremely helpful if you include a fast and intuitive way to setup animation of a sequence of frames. Pretty much like Chaos Vantage.
Now in 3ds max you need to spend significant time, to setup light cache to animation , render once to save the light cache, then load that cache.. then in max setup the frames , save …
It is chaotic and counter intuitive, compared to the extremely easy setup of Vantage.
Thanks in advance
Hello @digital_technologies
This should work with the current builds and there is a checkbox for running 4d people in GPU IPR properly.
Light cache is now calculated on GPU, you don’t need to pre-calculate for animation rendering. You can use the animation preset and around 1500 Subdivs to 2000(if you are rendering in 4k)
Best,
Muhammed
