I am trying to produce an animation that include some multiscatter object, they are ok util they don’t move, when I try to move them they stays in the first frame position. Is it something that will be implemented? Thanks.
I also noticed that they move inn max rel 2022 but not in 2019, so there’s some issue also in multiscatter only.
Hi litma,
How are you trying to animate the multiscatter? Vantage currently only supports translate/rotate/scale animations. Deformable animations are not supported but will be in the future.
Alexander
I tried eitheer by animating the spline where the proxies are aligned orjust by animating the proxies in advance. Both methods works in max but not in vantage.
Yes, these are not supported but are on the TO DO list. No ETA currently but will inform you once there is some development.
Alexander
so they cannot be considered translations?
