would be great if live link could pick up the VFB adjustments from vray GPU and take them across to Vantage or to at least be able to load in a preset saved from the max VFB
i do quite a lot of colour and image adjustment in VFB so its a bit annoying to have to rebuild again to match the look of the max vfb.
thanks
Hi squintnic,
I have logged in your request in our system, we will let you know when there is some development. As a workaround for the moment you can export the VFB layer stack as a LUT file and use that inside Vantage.
Alexander
ahh thanks that will work, i had forgotten about that feature
ok tried this and it looks very different to my VFB settings.
i also noticed on large scenes using live link the color corrections always reset to default, even if the file is saved? any work arounds for this?
the exposure values for cameras also dont match - im using a max physical camera would it be to do with this?
