Please add support for file Lens Distortions.
THE PURPOSE:
I have footage shot on 16mm (with lens distortions). Rendering background in Corona, but it doesn’t match perfectly, cause no lens distortions.
Applying the distortions in post - matches great, but the pixels are smoothed and blurred by post. Need to render with lens distortions already there.
The lens distortions can be obtained for example by this utility:
http://help.chaosgroup.com/vray/help/300R1/tools_lens.htm
.VRLens format is plain simple:
version 0.2
Calibration photo #0 begin
focalLength=16.000
k0=1.0230671
k1=-0.0544355
k2=0.0103712
squeeze=0.9922962
lambda_x=-0.0099095
lambda_y=0.0023432
flags=1Calibration photo #0 end
(Couldn’t find the second .lens file format specs.)
VrayPhysicalCam can load those .vrlens files and render using them (but only in vray, corona renders are still straight).
Btw, Corona supports Spherical vrayPhysicalCamera disctortions, but not File.
Also the parameters from Nuke lens distortion can be used (they look a bit different, but have Anamorphic mode also):
