Support with VrayClipper (with mesgmode)
For complex scenes with architectural buildings the Boolean Modifier isnt the solution. Vray Clipper with the meshmode on is perfect to open up a building without destroying the geometry.
Is it posible to make it work with Vantage?
Thanks for the Multitexture and Glossines refraction!!
kind regards,
Richard.
Hi Richard,
We have V-Ray clipper(LAV-623) logged in our system but it is not as high a priority at the moment. We will let you know when there is some development on the matter.
Alexander
HI, Is there any news on Vray Clipper support? the slice modifier is not a valid solution because for a building with many objects the solution is not to collapse everything into a single mesh.
Thank you​
another vote for clipper (same thing, architecture)
Yet another vote for clipper! It absolutely required! (in architecture)
another vote for clipper !
thank you for your work!
Filippo
