You can find the list of the supported and unsupported features of V-Ray RT here:
We will do our best to keep this list up to date but there can be some discrepancies. If you find any let us know.
To use the GPU engine you need video card that supports following:
1. OpenCL 1.1 or higher
2. CUDA 2.0 or higher
3. The CUDA engine for V-Ray RT GPU works on NVIDIA cards with the Fermi and Kepler architectures.
4. For users of NVIDA cards, we recommend the use of CUDA engine when rendering with V-Ray RT GPU.
whaou!!!
sounds like you have decided to put up to date the literature.
Congratulation, this kind of info are really appreciate.
Can you add the main plug in even if none of them are supported today:
ForestPro, Multiscatter, colorcorrect, Berconmap, multitexture…
There’s no reason why X-Ref scenes would not work in CUDA. If they don’t this is a bug that needs to be fixed, and not a limitation. If you can send us an example case to vray@chaosgroup.com it will be very helpful.
Ok. I think its something special and not a problem general. I double check it with a simple scene (sphere on a plane and had no issues.
But with my scene its still kind of mysterious. RT on CPU works fine, CUDA not. On CUDA the object appears just black, alpha is correct. I uploaded the scene and xref to my ftp. If you’re still interested, let me know I’give you the access and all the information for reproducing.
Sorry for the circumstances!
I don’t know if you’re making a prioritized list of what next to support in RT GPU, but I’d like to put in a vote for: Composite, Cellular and Smoke… in that order. Hair too -- but I imagine that’s a lot tougher than some of the other missing items.
I did a test using the full Vizpark Walls & Tiles version and V-Ray 3.00.07.
It works pretty well with V-Ray advanced renderer, but unfortunately our RT plugin doesn’t support their procedural maps. We have to extend the RT exporter support to get it working on the RT or through Vrscene file.
