Supressing the Old/New sampler dialog
Is there any way of supressing the dialog VRay shows when opening 2.x scenes with 3.x? Considering if I want to use new features etc.
I need to run a script on a batch of max files and using quiet mode doesn’t seem to work.
loadMaxFile "..." useFileUnits:true quiet:true
Nevermind, I found it in the scripting help:
setVRaySilentMode()
You could use setVRaySilentMode() - this will make V-Ray treat any message as if you clicked No. Then if you need the new sampler behavior you could check http://forums.chaosgroup.com/showthread.php?85677-Old-3-2-new-3-3-behavior-switcher&p=675059#post675059
Yavor
Thanks! :slight_smile:
