Surface edges showing when using displacement
Thta’s not the same problem though. The first issue was bad topology and this is just the blending of the randomised tiles, which is going to happen somewhat, depending on the map used.
In this version I added a triplanar and reduced the blend to an arbitrary very small amount to lessen the blurred joins, so there are no hard nasties as in your example. Hard to say whether it works without the diffuse but it may.
displacementTest01.rar (91.8 KB)
Thanks Fixeighted. I think I was going down the rabbit hole. Appreciate the help and guidance.
Hehe yeah rabbit holes are numerous and too easily encountered
On a final note/finding, if I switch from Vraydisplacement mod 3D Mapping to Subdivision it has much better results.
