Surface noise problem
Hi all
Got this noise problem on a project that I haven’t had in many years. It’s sort of surface/shadow noise that is some what different then the ordinary irradience splotches. I can compensate for the problem by cranking up the subdivs a lot more than usual, with very long rendertimes as a result. Any ideas on other settings to tweak?
(Vray 1.5 SP2 on Max 2009. Scene in cm 1:1)
Thanks from Chris
It is probably from the VRayLights; try increasing the subdivs value for them.
Increasing the light subdivs to about 50-60 gives the same amount of noise that I normally get in a scene with 16-20 subdivs on the lights :stuck_out_tongue: something strange is going on here!
Chris
Bigger lights than usual ? or closer than usual ?
A stripped down scene with only the lights and boxes would help..
Regads,
Thorsten
You have glossy surfaces - use adaptive dmc and increase glossy subdivs on 'em. Also you may try to rise the AA to smth like 1/8 + increase subdivs to smth like 35 (materials and lights).
Can you show your vray settings ..
