Swarm - 'Cap CPU Utilization' doesn't seem to be capping...
Under Swarm settings, I switch the ‘Cap CPU Utilization’ slider to ON, but my local CPU is still running 100% (across all 12 cores). Any ideas?
As im not familiar with your environment i can only give you advice based on what ive experienced before.
Are there other devices in the swarm that may be rendering? Is it possible another device is rendering to your machine? This means that your machine is only using 1 thread but someone else is using the rest. Try disabling your Device as a swarm node?
http://localhost:24267/network and flick it to disabled.
Hi @GD3DESIGN
Could you please advise what is the full version number of V-Ray and V-Ray Swarm you are using? Additionally, please provide the full specifications of the computer.
