Swarm not rendering select proxies
I’m not sure why but when I render using swarm select proxies do not appear. When I render only using my local machine I don’t have that problem. Also, when I render using Progressive rendering with swarm on not even Laubwerk landscaping appears. Is there an easy fix to this?
Seems like the machines assisting in the render job cannot find or load the proxy files. Where are they located?
Also, what is the full version number of your V-Ray for SketchUp?
Could you please do the following test:
1. Open a project which exhibits the issue, add DRBuckets render element from the V-Ray Asset Editor’s Settings panel and also disable the Progressive render toggle.
2. Then open your internet browser and type in the IP address of one of your render node machines followed by “:24267/log”, e.g. http://10.01.2.95:24267/log
3. Click the button at the top-right corner and choose “Clear browser log”
4. Render the project using V-Ray Swarm.
Once done, please send the rendered images for RGB and DRBucket channels as well as the whole Swarm log as .txt file. You can email all this directly at support@chaosgroup.com together with a short description or a link to this forum thread. We will be able to assist you further based on the result you share.
Kind regards,
Peter
