I usually use the sweep modifier to add base boards to my arch viz projects, however, usually after making some adjustments such as removing unwanted segments for doors and openings I get certain segments in a flipped orientation. Part of my floor boards are facing into the walls, this drive me nuts because I have to delete the “bad inverted” segments and create a new lines with a sweeps.
Its there a way to flip the orientation of a line? like flipping the face of an element?
Add an Edit Spline modifier, select the sub-object Spline you want to change, and click Reverse in the Geometry rollout. This will flip the resulting extrusion which I think is what your after.
Glad to help. OT: If any one has an idea how to change the “normal” orientation of a spline I’d love to hear it as well. I’ll often try to add an extrude modifier to splines only to have the extrusion stay in the plan of the line which makes it useless. Frustrating!
e: misread. that depends on the view you’re in when you start drawing it. usually pops up when you extract splines.
for that i rotate it 90, reset x form, collapse to spline, add extrude and rotate back. you’re not changing the pivot position so it’ll land in the same place.
