swimming pool light
I have to render a pool with lights inside, but I’m not able to achiev the typical effect of the light in the water…could you help me?
have you tried the scatter light plugin ? :wink:
Are you talking about the dancing light pattern aka caustics? if so, use caustics with vray, or use an inverted smoke map as a projector map on your light sources (standard lights).
thanx everybody.
@natty: what is scatter light plugin?
this is the link
http://www.afterworks.com/SVLfirst.htm
but its only for max4-max5
fantastic!
thanx
