Symmetry Object problems
Am I the only one to whom elements don’t render if they have the same name within a Symmetry Object.
Same here, the render instance option is also more efficient for both viewport and RAM usage so I do that regardless of the symmetry issue.
Does it not cause normal flipping (bumps on the wrong side etc.)?
No, at least in render instance mode the normals are fine.
As @klex167 already mentioned above, this is a known issue (bug ID: VC4D-976), that has already been reported in our system. I made sure to also mention this thread and I will let you know once we have any updates on the matter. Thank you.
