Hello, we are two friend working together at free time, we will share our test renders and work in progress renders, previews etc.
Thank you.
This is the first image from upcoming project.
Toyota_Tacoma_LookDev-01- Some dirt, mud, imperfection added.
I like the water test! Which tools were used to simulate it?
Thanks. Simulated with Maya Bifrost
Cool! What’s the process for getting that simulation in and rendered using Corona? OpenVDB? Any magic to the material settings once imported? Or is it a compositing of a render from Maya with a render from Corona? Cheers!
I exported water and foam as alembic from maya, this material is just for testing not finished. I combined two material with layered material, base material is volume material and layer 1 has standart water material. Also my English is not perfect, if i write wrong somethings sorry for that. ![]()
TY for the info, cool to know how you are creating it, thank you for sharing! Also, it is looking good already, especially if just a test ![]()
That water is really great! I’d like to see it in higher resolution and better quality.
I don’t think mixing two materials with layered mtl is needed. Creating one water material with volumetrics should be enough, and it should render faster.
Thank you! New items added to back of truck and added little dynamics. And i gonna give a trick for importing alembic to 3dsmax. while you working at 25 fps if import an alembic file from maya then you will see it’s fps not matcing with your animations. I found a solution; before importing alembic file i set fps to 30 from settings in 3dsmax, then i import alembic and then convert to 25 fps again, and problem solved.
All is looking pretty nice!
A question - why not sim the water directly in Max? It has Bifrost (even a fluid loader) that way you avoid bringing huge alembic files back and forth.
Man these are really awesome, its fun keeping track of the progress here
Thanks for sharing!
From a subjective point of view, I personally kind of liked the previous foliage a bit more. This one seems more like the usual foliage you see in similar images with a heavy terrain vehicle. Could be just me though and no disrespect to the foliage
… Anyway, liking the work!
