Tag composting issue?
Usually when I create an interiors rendering I put a simple panel outside the scene with Light Material. To avoid to make shadows into the room I put a compositing Tag onto it but, see what happens on Corona 10 instead of Corona 9 where the functionality works fine…
EDIT: I noticed that if I uncheck “emit light” into the light material the shadow are deactivated without using the TAG…some behaviour are chanced I think…:face_with_monocle:
Hi @masterzone.
Thanks a lot for bringing this to our attention.
Are you able to share your scene project with us?
(please include all necessary assets)
This way, we can investigate a bit further your file’s overall scene setup.
Looking forward to hearing from you.
Kind regards.
sure Benjamin, here attached you can find a simple scene.
  1. start the IR
  2. go to Composting Tag settings
  3. toggle “cast shadows”
You will be able your self that lights stop to emit…
I remember that works fine with previously corona render…
OS: Sonoma
C4D: latest release
Corona: latest release
composting.c4d (222 KB)
Hi @masterzone
I’m sorry for the late reply.
After looking at your test scene and understanding your workflow, here are my findings:
-For cases like this one, where you want to use a backplate (plane + a Corona light material) to mimic a background outdoors, you’re correct by choosing to use a light material that will be applied to the plane object; however, I’ll suggest disabling the “emit light” checkbox from the Corona light material instead of disabling the “cast shadows” checkbox from the Corona compositing tag.
I’m including a modified version of your scene file so you can test it and experiment with it.
I hope this helps.
Kind regards.
41161.zip (8.19 MB)
thanks so much, may some internal engine behavior where changed into the corona 10. Thanks for your tips I will return to use the light material with emit light turned off.
I also noticed the tone map control shader into the light material…and I take a look to the online help to see what kind of shader it is…believe me, the ton map control is a personal request feature that was in my dream from the first commercial release of corona render!!! I never used it before! thanks!!!
