Hi!
I have added hair to an object and made some different Takes to adjust object rotation etc. My problem is that the hair does not follow along in the takes. Not sure this is a Corona issue or a Cinema 4d issue (or an bad user-issue). Any tips? Uploaded test scene on Corona Upload-page.
See attached images
No ideas? No pubic hair experts here?
Hi there, I saw that you had uploaded a file to us, I rendered it out with using your saved takes and all was okay. The hair stuck to the mesh. Soooo I’m not sure what the problem might be…
I’m no takes expert by any means. I think this was the second time I’ve used it
All I did with your scene was turn on the main take and rendered it via TeamRender.
Aha! Then I see. That works here as well. What does not work if you render all Takes. Try that and see what I mean.
That’s actually how I rendered it. I just used the “render all takes” button, not individualy.
