is there a way to influence the Render Elements with the Take System? I tried it, but maybe I’ve just overseen something, ss I am not so familiar with the Take System.
@haniel1107 You can if you render and save with in vrimg format in the output system in the common tab instead of using the cinema 4d save. Then reload the rendered file back into the VFB window. Go to file upload. Then save the changes. Not the most efficient but it works. I hope they can implement this into the take system in Cinema. They should add a drop down in takes menu and have another option send all takes to VFB. I have asked for this feature. You can log in and vote for this here. https://chaosvray.ideas.aha.io/
Hi @THSCreative , thanks for this! I will try it out. But as you wrot, would also prefer the implementation… saving in vrimg format, would be mean a different worklfow for me… Thanks!
@haniel1107 You’re welcome! Once you load the vrimg in to the VFB you can save it to another format like .jpeg , .png. tiff, etc. Here is a good video that explains the process. https://www.youtube.com/watch?v=rr\_e4RrvPuI
Thanks ![]()
