I made a simple scene for one client and it’s taking too long to render and i have too much noise in the scene.
It takes 15 minutes to calculate and to get this result 3 hours . Resolution 2000x1160.
I use only corona sun and three corona portal mtl. The rendering settings are the defaults.
Any ideas why it’s taking too long and about hte noise??
Hi Maru!!
My system is an intel i5 2,26 ghz, 120 ssd, 8 gb ram
I dont have any particular geometry ,and my materials are very simple, i used many of them from materials corona settings.
If needed i can show materials.
I placed the portals nearly inside the glass material…
I allready tried putting the portal just outside… same time…
and i putted inside to bypass the glass if there is the problem…
is very strange for that scene to take that long… my previous one was 5 times bigger and i had no problem…
I didn’t quite understand about the HD cache… i have two one is 120 GB SSD, and one is 750 GB HDD on the same laptop… if that is you mean…
The appliances over the kitchen looks suspiciusly brigth. Check those with an albedo pass (add them in the render elements tab F10)?.
Also double check your windows glass material refraction mode.
Did you illuminate with geometry emitting or hdri?
Not HDD but HD cache. You should always have “HD cache” as secondary solver in interior renders.
If it’s not the case, then maybe you will find some hints here:
btw, question of the year: what does HD in HD cache stand for?
i thought there was an hdri in the environment slot because trough the door we can see some background, and sometimes reflect materials without fresnel looks like they have a metalic cover (as the coffe machine has).
I 've placed a plane and a bitmap … i do this often to match real outdoor for the living space i make the render… this particular is a photo taken from the balkonie of the house..
I can’t find though a solution to my problem.. i tried everything… i also cleared the scene of any objects still too slow…
One last…
Why dont you try the “Mtl. override”, assignit a defaut Corona Material and exclude geometry (like glass for example) one by one until you find the offending peace of geometry?..
Not one by one off course, you can do it in groups. Just cheking stats in the corona render frame until you see a dropdown.
Did you turned off cast/receive shadows and visible to reflections/refractions options for that plane, or is it sitting between your enviroment and your subject and blocking most of the light?
Oh my god!!!
So you say that i must turn off shadows and visible to reflections …???
i must finish a bathroom that i’m doing and i’ll give it immediately a try!!!
Thank’s Guys!!!
Thank’s Guys!!!
It realy was like magic happens!!! i putted a coronalightmtl with disabled the emission and the total time dropped dramaically!!!
In 45 minutes and 2000x1120 resolution i have this result!!! which is a very nice time!!!
The others would take me at least 2 hours to reach this results!!!
