Tall Meadow Grass
Hello All,
Ive been searching the net and the forums lately on how to create tall meadow grass ive being doing i tby comping it in photoshop however i would like to attempt it in cg… howver i have just tried creating it with some othe methods ive read about mainly VRayFur. Im running vray 1.5 on viz 2008 using Dual Dual Core Xeon’s and 4 gigs of ram with the 3 gig switch.
Well ive followed settings such as the one found here:
http://www.vray-materials.de/forum/attachment.php?aid=77
however sicne its jsut a test im running teh test with very low preset in the GI and only at a resolution of 640x480
and well the render time keeps climbign its at 1 hour 40 mins and climbing on the estimate… what am i doing wrong?
anyones thoughts would be helpful
humbly yours
lost in a field of flat grass
Ryan
Hi Ryan,
It could be your base geometry that’s the problem. I made some rugs for an interior using VRay fur that took about 30 mins to render. After adding a subdivide modifier the render times dropped to under 2 mins.
Might be the same problem…
Dan
thanks for the tip dan,
i tried it however the render times still went up to an hour + a 10m x 10m plane
im going to have to find a better way of makign the tall grass :frowning:
For a large scene, where rendertimes need to stay low, forgive me for saying this, but I’d just model a few pieces and starting instancing. You’ll get the best rendertime and best control that way.
Oh well, it was worth a try.
I think I used a size of about 50mm, even then the lightcache does initially think it’s going take a few hours but then suddenly the time drops to less than a minute.
thanks everyone for your suggestions im going to try a them and keep playing with it!
thanks!
Ryan
When using a large amount of fur, displacement or vrmesh it will speed up your renders a lot if you increase the dynamic memory to around 2 GB.
