Tapered edges with Corona wire
Using latest hotfix version My edges are tapering in some places.
Is there a work around for this?
Image attached.
Is it different if you render with an older version? Can you check with the same scene?
Similar issues are there for quite some time, and it’s reported, so we are planning to fix/improve it, but no specific timeframe yet.
I can’t check older versions at the mo as working to a tight deadline. Have the same issue with Vray also though.
I have found a workaround. Rendering thinner lines and then using Minimum / Maximum filters in Photoshop to adjust thickness. So I think I am OK for now.
Thanks for your help! :smiley:
Leaving this open and moving to bug reports, as we may look into it at some point.
Duplicate of https://forum.corona-renderer.com/ CoronaWire Line breaks when Isoline Display
