Is anyone else having issues with the target camera ? It seems to cause issues when rendering using DR or backburner ? Positions are incorrect.
Could you please clarify the issue? Which V-Ray and 3ds max version are you using? Also what do you mean by incorrect positions? Can you attach a simple scene?
Also do you use the same V-Ray version on all of the nodes and does the issue persist with a particular machines?
