Target CoronaSun
Hi guys,
I downloaded the 1.2.1 version. Great update!
The only thing is I saw the CoronaSun has changed to a target Sun.
I used the “old” angle/direction sliders a lot.
Can you put them back on the roll out? For instance if the Target checkbox is turned off?
I don’t want to be reactionary btw :smiley:
Thanks,
Jeroen
The old sun model was removed because it was hard to use in some scenarios, for example animation, as it relied on spinners, and couldn’t be rotated in the viewport. With the new sun, you can disable “targeted” mode, switch to object rotation, and input the numeric values in the spinners at the very bottom of 3ds Max interface. It will work exactly the same as the old model.
Didn’t realize the animation limitations. I’ll rewrite my maxscript (uses the sunrotation property)
I only make stills :smiley:
Thanks for your quick reply!
Wasn’t viewport lighting the main reason behind replacing old CoronaSun with new one? Anyway, you can try daylight system if you prefer numerical input control.
Yes, viewport lighting too.
New Sun system is pretty messed up.. Need old system .. as sun position and angle can be easily adjusted using modifier in old one.. or at least implement them in sun modifier panel..
New sun is really annoying.. Bitch Slap to new sun :smiley:
Thanks..
I like the new sun system more, but I must admit that it was a helpfull thing to have all the angles visible.
I would like to see what angle Im puting my sun at, even when I do it on target mode, it still could allow for the use of controllers angle, angle and distance. Would be a great thing.
Guys, have you really read this topic and seen the screenshot by Rawa?
I’m sorry maru, but i think that method suggested by Rawalanche is plain rubbish. It’s nowhere near as convenient as old sun controls was. I’d rather stick with daylight system. OTOH i’m getting used to new sun and doesn’t feel much need in numerical controls anymore :]
Could you post an example of what you mean? Are you sure you are not mixing modifiers with controllers?
Yes i mean controllers.. they should appear in modifier panel like last sun.. so one can just rotate sun and angle from there.. rather then manually moving it.. trust me its hard to do that also most of the times it require to zoom out from view.. i like to stay within my cam and see results on IR while i rotate or play with sun params.. this allow me to create prefect sun positions the way i want..
Thanks :smiley:
Here is a sun with angle control made in about 5 minutes. You can download the file and merge it into your scene whenever you need it. You can also add a fancy compass object to it if you wish. :wink:
It was made in daily build, 3ds Max 2016 and saved to 2014 so let me know if there are any problems with it.
angledsun-14.max (248 KB)
Hi maru, is it posible to use your sun “arrow” linked to an Hdri? Using the sun with 0 Intensity, just to get the visual help of the rotation (just horizontal rotation)
Thx for the sun btw
Hi, I think this should work, but haven’t checked yet:
When i try to do that the moment i try to change the sun rotation using your sun 3dmax crashes at rendering time
Then you should report it as a bug.
Strange. Could be a 3dsmax issue. Are you linking the sun position or the custom spinner? (I think it should be the spinner)
Here is a guide on reporting bugs: https://coronarenderer.freshdesk.com/support/solutions/articles/5000524006
(probably point 1 or 2)
reported, hope that its not my fault :wink:
