TeamRender has been extremely unreliable using Corona over the past few releases. I don’t know if something has changed in the builds or on my system but I have problems running even the simplest jobs. Projects run perfectly with the native render and Vray. Projects seem to fail near the end and usually can be restarted multiple times to get it to finish. Previous builds would crash the clients but I don’t see that anymore with 08-29 build they just drop the job, all clients go idle reporting the same error.
(Error) Render-Job failed: Rendering stopped because of an out-of-memory or unknown error
2017/08/29 13:58:22 Cancelled because all attending machines failed
2017/08/29 13:58:22 Render Failed
I have re-installed the server and clients, re-installed Corona, removed all plugins and Vray. I even rolled everything back to a previous build that used to work flawlessly. Nothing seems to help fix the issue, It worked very well until about a month ago and I have not been able to sort out what has changed.
system specs:
1 machine running Server app
8 render machines running client app
TeamRender 18.057
Corona 08-29-2017
OS X 10.12.6
As you’re probably aware, the latest build came with a lot of fixes and changes to the Team Render, so it is only expected to have a bug or two. But don’t worry, we’ll look at these bugs and do what we can. Just for clarification:
Are all your machines Macs? Or do you have Windows clients and one Mac server?
Does the issue happen with all the scenes?
Also, do I read it correctly that now even the older builds fail for you?
Could you please try to render simple scene directly with Cinema 4D (not the CINEMA 4D TeamRender Server) with only one client and then send me the output of Cinema 4D Console (Script → Console) and the output of the CINEMA 4D TeamRender Client Console (Console Tab). Thank you
Thanks for your patience!
Cestmir
All machines are Mac
Seems to happen with all scenes. I even made some very simple scenes for testing.
Yes it started happening with older builds. That is the most troubling part of it. It started right around the time of the last update from Maxon. I even contacted Maxon and rolled my Cinema install back to the previous version. There was even a OS X update at the time so I have had a very hard time trying to figure out what is causing it.
I didn’t report it sooner as I was hoping the work on Team Render in the current build might make an improvement.
Ok, I think I understand what you are asking for.
This is what I did… created a simple scene > enabled one machine in Team Render Machines > Team Render to Picture Viewer > results attached
No error. But all of my problems are when submitting a job to my render farm and using Team Render Server & Clients. I never use “Team Render to picture viewer” on my local machine.
According to your screenshot, it looks that Corona is not loaded in the Team Render Server. You can check it in your Team Render Server Web UI on Network page after clicking on Plugins section. If there is no Corona plugin listed then start Team Render Server with following command in the Terminal and send me the output please:
/Applications/MAXON/CINEMA\ 4D\ R18/CINEMA\ 4D\ TeamRender\ Server.app/Contents/MacOS/CINEMA\ 4D\ TeamRender\ Server
Ok, I did not have the Corona plugin installed in the server app. Once I put it in the plugin folder I am now able to render a single frame through Team Render server + clients. But instead of one machine taking the single frame and rendering it all machines render it together. It took my 8 servers roughly the same amount of time to render the image as it did rendering it on my workstation???
Is there no way to send a single frame and have only one server render it?
I am back to my original problem, if I send a 20 frame animation only one server will pickup some frames. And once it completes some frames the job will fail this happens over and over. Start it again, render a few frames fail again. I have attached a log showing me trying to render a 20 frame sequence.
Today I successfully reproduced your problem. Team Render in Cinema 4D has two modes. The first mode is Team Rendering of animations when each client gets some range of frames which are rendered by normal (local) renderer one after another and finished frames are sent back to the server (all communication is handled by Cinema for us). The second mode is called “Single frame Team Rendering” which is started by Cinema when only one frame is being rendered (no animation). In this mode, each client renders the same image, but with a different seed, i.e. different pass and all these passes are sent back to the server and combined to produce final render. In this mode, we must handle all communication (but not only communication but also saving, nearly everything) by ourselves and this is what I was mainly fixing in the last daily build. Despite the Cinema 4D is handling the animation Team Rendering for us, there is probably some bug in local renderer so I will try to find the cause of it today.
Thanks so much for your help Nikola, I am not sure what bug you reproduced as I am having multiple problems.
To be clear my main and most severe problem is when rendering animations using Team Render server and clients. My local machine is not involved at all. I am saving project and assets and placing them on my server and starting the rendering using the Team Render server web app. When I do this I can not get a job to finish. It doesn’t seem to assign the frames correctly to the clients and once they finish rendering a frame or two the just go offline.
I successfully reproduced the problem when rendering jobs are not able to finish. But why are you saving the whole scene and using the Team Render Server web application? For me, it looks easier to turn your Team Render Server to ordinary Team Render Client and simply use the “Team Render to Picture Viewer” (when the bug with unfinished jobs will be fixed). You can also use your main machine as the client by enabling “Edit → Preferences → Renderer → Team Render → Share Machine over Network”.
Great I’m glad you were able to reproduce the problem and I hope it is an easy fix for you.
For our studio the web app is much better. We have multiple people sending multiple jobs. When a project is ready to render I have a little script that collets all assets saves them to the admin folder and I just need to press start in the web app and keep working. My machine is not affected and the farm just renders our jobs. This works great to queue up both still frames and animations and all users can view progress, quite jobs, change priority, delete jobs, get there final renderings etc. Much more seamless and effective.
I might use it the way you suggested if I was the only person rendering or if I have an urgent rendering that needs the combined power of the whole render farm.
Fantastic work Nikola! I tried it with a simple scene using Team Render R19 and it appears to work very well. I will give it a good test this week and let you know if I encounter any issues but it looks like you fixed it. Thank you so much for getting to this so quickly!
I have been reading this thread and Shane has kindly been assisting me in setting up my team render server.
However, I have a few issues with how it is all working.
I am finding that when I try to render a still on the Team Render Server using the web app, it spends a loooooong time preparing and then crashes.
I have used Shane’s hack to render a still as a single frame animation which works, but if I try to harness the power of all 14 machines for one image it fails every time.
Well, for 14 machines you’d need an extended Corona license - the default license only supports 3 render clients. How many render nodes do you have with your license?
i was wondering if anyone still has this problem. we also have problems rendering jobs and jobs getting stuck at the last frame and wont continue. very very frustrating because you leave the renderfarm running over the weekend, only to find out it rendered 10% of your jobs. not very eco friendly either.
is that on coronas side or is that a c4d issue?
we use macs and windows pcs. most of the time it works and the solution is to stop and start the render again.
