Team Render is not saving the image after finishing the render
I’m using Corona A6.3 with R18.041 on Mac. I have a problem when I use TR it doesn’t save the rendered image. I have one main workstation and one client they both have same version of C4D and Corona. If I checked the image in Corona VFB it’s done but the file is not saved. I’m rendering a still image. I tried every thing I can think of but it’s just not saving the image. The problem is with TR cause it doesn’t save the file even when I disable the client and use the main workstation but within TR it still doesn’t save the rendered image.
Ali
Thank you for the bug report. I am fixing the teamrender right now. Your problem will be fixed in some upcoming daily build.
Nikola
This still doesn’t work in Julys update..
