Team Render output to dark / Camera Tag issue
Hi there,
i noticed today when rendering with teamrender, the output is way too dark. i read somewhere to fix it with the filter from the PV and it is working. i have to correct gamma and exposure to come to the same result when rendering with the main-workstation.
can you have a look at this?
update: after some reading in the forum, i thought to copy the settings from the camera tag to the “Corona Camera/Postprocessing Settings” and disable the “override” options in the camera tag and now it seems to have the correct output, no filter in the pv needed. it seems teamreander ignores the camera tag and uses the default “Camera/Postprocessing Settings”
thx, stefan
1 workstation (Win10) + 1 client (Win7)
use photographic exposure “on”
Thank you so much for posting your follow-up solution. I can confirm that your conclusions are correct.
