Team Render results don’t save to disk
Team Render isn’t saving any renders to disk upon completion. It will save the main image when an absolute path is set, but no multi passes. With relative paths it won’t save anything.
We use one render setting with a relative path and naming tokens to avoid duplicating render settings for each shot. Needing to save each pass manually is a problem, especially when rendering overnight as renders are erased when the picture viewer cache is exceeded, resulting in lost renders.
We’re using R21.026 with Daily Build 2019-09-20. All machines are iMacs running OSX Mojave.
