Hi there,
We are running into an issue using Corona (both 5 and the latest (June 30) daily build of 6) with a team render server+clients setup.
The problem is as follows:
When we try to render a C4D scene that has 1 frame (So it splits the one frame over multiple machines), the entire render server crashes. When we restart the render server, the job we just started is indicated as “complete” without results.
If we have started multiple projects, it will be rendering a different project from the one we started when the server comes back online.
We are trying to render one frame on multiple machines to speed up the rendering process.
When we take the same exact scene, give it 2 frames (so it will render 1 frame per client), the render server works fine and there are no problems.
When using Corona 5, when rendering 1 frame on multiple machines, even when it finishes, there is a color difference (looks like different exposure or if some lights are switched off) in the image which does not happen when we render the same frame on 1 dedicated machine. (All machines are running the exact same Corona version so this can not be the issue I imagine)
When using Corona 6, when rendering 1 frame on multiple machines, there is no color difference anymore (All machines are running the exact same Corona version so this can not be the issue I imagine)
When using Corona 5, when rendering 1 frame on multiple machines, if you start a job like this, the render server crashes. (All machines are running the exact same Corona version so this can not be the issue I imagine)
When using Corona 6, when rendering 1 frame on multiple machines, you can start 1 job safely but as soon as you launch a second job the render server crashes. (All machines are running the exact same Corona version so this can not be the issue I imagine)
I’ve attached the bug report zip of the latest crash with Corona 5 (I believe) called _BugReport.zip which is the crash that happens when you try to launch any job that splits over multiple machines.
I’ve also attached the bug report of the latest crash with Corona 6 (30 June) called _BugReport_Corona6.zip which is the crash that happens when you try to launch more then one job.
As I said it happens with multiple Corona versions.
This is a rather serious issue for us as we render a combination of animation but also high res single images most days and having the render farm crash all the time is rather frustrating.
Cheers,
Joep
_BugReport.zip (74.3 KB)
_BugReport_Corona6.zip (73.1 KB)
