Team Render to Picture Viewer Bug on Mac
Hi folks,
under OSX / mac the photographic “Override”-section within the camera tag doesn’t override the general settings when rendering a single frame (DR) while using “Team Render to Picture Viewer”
We testet a lot of stuff. When rendering animations everything works fine. When using the “Simple Exposure”-Overide Feature instead of “Photographic Exposure” either.
It seems to be a problem only while using the “Photographic Exposure”-overide in combination with DR.
Best
Frank
Some Screenshots
@DH3 This sounds like the same issue we had, as well as others in the past. There’s a bug with the camera tag and the devs are aware of it. The simple workaround is here in a quote from my previous post:
“As far as I know, the Corona Camera Tag on the Mac is still an issue. If you copy the camera tag setting to the Camera/Post Processing tab in the render settings and check Use Photographic Exposure, everything renders fine. At least it’s an easy workaround.”
