Team rendering slower(?)
Hi!
I finally got Team render to work fine.
The only problem is that it takes longer to render the image via Team Render.
Is this normal / or due to pre-production build reasons?
Kind Regards / Alex
It takes longer to render than what? Than what it used to be or than local render?
Hi!
Sorry for not being more clear.
Yes, Team Render is currently outputting results considerably slower than the local renderer.
Cheers / Alex
Hi Alex,
how many clients do you use? But we know that current scheduling algorithm is not ideal and will be improved when all major bugs in Team render are fixed.
Nikola
Hi Nikola!
I’m currently using 9 out of 10 clients. (see attachment)
Kind Regards / Alex
I have the same problem.
At localrender within 15 minutes I have 72 pass.
The 2 TeamRender machines are just 45. What’s going on?
