tensile anyone?
hehehe my recent work trying to recreate existing building that ive seen from archdaily.com
my attempt
still doing it to improve the overall outcome
C&C much appreciated
Re: tensile anyone?
Nice render. Background sky fits very well. I like the transparency of your roof. But I would like to see the white lights less bright maybe.
Re: tensile anyone?
The best way to create the roof is using a Vray2sideMat. This material is for simulate translucency.
Best
Re: tensile anyone?
thx ken.maybe ill try to lwer down the value on the light. but the problem is that i cant simulate the tensile material (polyester? nylon?) properly. what happen here is, i used material setting using available white plastic material and give a bit translucency on it.
i tried using it to apply transparency only for the light to penetrate through the material but in the picture almost all thing that are behind it appear.
by apply 2sidedmat should i use the same material for both sided or different 1?
pardon my english
Re: tensile anyone?
For the back side use a darker material.
Re: tensile anyone?
You can use the same material as well
Best
Re: tensile anyone?
That is mind blowing. :o
Can you post a raw image
Re: tensile anyone?
did u mean the sketchup model?
here
Re: tensile anyone?
whoewww. beautiful render. my only thing to comment is the paralax effect of the camera. i guess to much distortion. i hope next time vray could have a guess verticla shift in the camera like in vray max.
